70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Template to Project
Tue, May 31, 2011 at 1:47:34 AM | Template to Project
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
I made a template at work and saved it as a template. Now when I open it I cant save as a project only template. Is there anyway I can save as a project and is there much difference with saving it as a template or project?
Revit 2018........
Tue, May 31, 2011 at 5:11:25 AM | Template to Project
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Looks like you are double clicking on the file. Open the Revit application>>Click on Application Button>New >Project, then select the template you have created and make sure 'Create Project' is selected and click on OK. Now you can save it as a project.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Tue, May 31, 2011 at 7:22:12 AM | Template to Project
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
ohhh good man thanks heaps for that mate. Much appreciated. Was driving me nuts. Thanks again.
Revit 2018........
Mon, Nov 5, 2012 at 7:04:08 AM | Template to Project
beyrami
I have a problem like so.As I start a project usig template files, Revit does not bring anything like levels and ... . can you help please
Mon, Nov 5, 2012 at 7:13:41 AM | Template to Project
You didn't ask any questions but I will say, levels are included in a template if you put them in it.
Mon, Nov 5, 2012 at 9:13:17 AM | Template to Project
beyrami
I totaly undrestand that. But the problem is my Revit does not import anything even from default templates
Mon, Nov 5, 2012 at 9:33:13 AM | Template to Project
I am assuming you are saying that you started your project using a different template and now you want something that is in a different template - correct?  Start a new project using the template you want the data from and import from that.
Note - For some things, you may want to use transfer project standards.
Mon, Nov 5, 2012 at 12:21:29 PM | Template to Project
beyrami
let me explain this way. starting a new project using a default template and  starting a new project not using any template file does not differ in my Revit. in both of them no families are loaded.
Mon, Nov 5, 2012 at 1:52:14 PM | Template to Project
Well then, fix your template! Open the template file, load the families and save it as a template.
Every office should create their own template with what they need.  The default always has some very fundamental, system level walls, doors etc unless someone in your location deleted them in the template.  (You can't delete some of them.)
Tue, Jul 31, 2018 at 2:25:33 AM | Template to Project
anishac55
OEPN NEW- REVIT PROJECT- NAVIGATE YOUR RTE FILE YOU HAVE BEEN WORKING IN
save new template from project
Tue, Nov 21, 2006 at 7:16:16 PM
Changing a template to a Project
Tue, Feb 2, 2010 at 7:03:24 AM
Trying to make a template out of a project that had worksharing enabled
Thu, May 28, 2009 at 2:03:54 PM
Changing template to project
Sun, Dec 12, 2010 at 10:51:02 AM
Project Template
Thu, Oct 28, 2010 at 10:50:07 AM
Page generation time: 2.5421
