70 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> revit error messages
hi
I am trying to make a roof by footprint. everything seems ok to me however revit is giving me the errror message - 'Can't make footprint roof.'
Helpful ay.
Can someone please tell me why revit knows when you are doing something wrong but doesnt tell you what.
need more info or the file your working on to know what the problem is.
It could be numerous things. The assigned roof pitches may be causing revit to not be able to generate the roof shape, you could have overlapping lines somewhere in the sketch, you might have applied a slope to a curve that merges into a straight section that revit cannot calculate...
Best bet is to check the overlapping lines first. Tab select the strings of lines, copy to clipboard then delete them... Are there any lines left over? If so delete them and paste aligined back the sketch. Also, trace along the sketch and ensure all lines are trimmed to each other appropriately.
HTH.
error & warning messages |
Fri, Oct 27, 2006 at 4:01:28 PM
ERROR MESSAGES |
Wed, May 3, 2006 at 8:41:53 PM
KEYNOTES - v2010 error messages |
Tue, Nov 24, 2009 at 3:42:12 PM
Revit error messages |
Wed, Jan 21, 2009 at 6:41:48 PM
messages in the drawing |
Wed, May 1, 2013 at 7:34:35 AM
Members: | 2057523 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
