101 Users Online (99 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Publishing a .dwf File
Fri, May 27, 2011 at 1:42:01 AM | Publishing a .dwf File
raja15
I have tried publishing a .dwf file via:
File > Publish DWF > 2D DWF...
I have then selected the various settings I need for this particular project.  Ie - File type, File name, File location, Print setup, Options, etc.
I've then clicked save, and Revit has appeared to have loaded and saved the file in the desired location with all my settings, etc.
Upon going into the server to open up the file, I have discovered it is not there.
I have tried publishing it via another computer which is connected to the server.
I have tried publishing one sheet at a time instead of a big file of 20 or so sheets.
I have double checked that the location I intended to save it to has been correctly outlined in the "Save As" dialogue box.
I have double checked that I might have saved it in the wrong folder somewhere.
But I am still unable to come to a conclusion to where this may have saved, if it even saved at all.
If someone would be able to help me out with why this is occuring, I would greatly appreciate it.
Thanks.
uNRECOVERABLE ERROR WHILE PUBLISHING .DWF SET
Tue, Feb 13, 2007 at 1:53:27 PM
publishing dwf files
Wed, Jun 2, 2010 at 12:31:49 PM
help! dwf for 2d plans
Sun, Feb 26, 2006 at 8:15:58 PM
DWF File Size
Fri, Oct 26, 2007 at 9:52:19 AM
Revit 2012 - export DWF - corrupt dwf file
Fri, Aug 3, 2012 at 10:47:12 AM
Page generation time: 1.6460
