97 Users Online (96 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> chamfer edges
Thu, Nov 17, 2005 at 6:04:14 AM | chamfer edges
andyp
hi, im new to revit - can somebody tell me easiest way to chamfer the edges of my model? cant find any sort of chamfer tool!? using revit 8. cheers andyp
Thu, Nov 17, 2005 at 6:06:22 PM | RE: chamfer edges
eldados
eldados Avatar
4.5 Stars: 8 Votes
there is no chamfer tool as such, do you need to take the corners off? use voids to cut it. are you talking about walls?
Integrator
KarelCAD
Fri, Nov 18, 2005 at 3:42:31 AM | RE: chamfer edges
andyp
exterior walls - they seem abit too sharp - was wondering if there was an easy way just to take the edge of them a little - cheers for the reply - ill have to have a play round with them.
Fri, Nov 18, 2005 at 3:55:52 AM | RE: chamfer edges
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You could use a vertical wall reveal on the corners... The walls would all have to butt jointed though...
Mon, Jan 18, 2010 at 11:15:46 AM | chamfer edges
Yosemite
Good morning. This is similar to my question about chamfering the corners of walls. I want a 2" chamfer at the corner of a building or column; but I want the chamfer to start +2' above the floor and stop 2' below the roof. You suggested butt wall corners and then chamfering. I'm new to Revit 2010. Can you provide a step-by-step procedure or website directions? Thanks.
creating a chamfer on edges of an extrusion
Tue, Apr 21, 2009 at 5:47:05 PM
chamfer
Mon, Apr 7, 2008 at 4:59:25 PM
Foundation wall chamfer
Thu, Sep 29, 2011 at 10:58:22 AM
Chamfer line tool
Thu, Nov 18, 2010 at 1:35:20 PM
Wire Chamfer
Thu, Apr 12, 2012 at 4:14:03 PM
Page generation time: 0.2599
