94 Users Online (93 Members):
Forums >> Revit Structure >> Tips & Tricks >> DIMENSIONing GRIDS - on plan view
49 Posts No Rating |
Just discovered an easy way of dimensioning multiple grids at one go on plan view.
-> Draw a wall across all grids such that some portion of wall projects outside first and last grids.
-> Select 'Aligned Dimension'.
-> On option bar, Pick 'Entire Walls' - click 'Options' button, select 'Intersecting Grids'.
-> Now, select the wall for dimensioning.
-> After placing dimension, delete the wall.
Additional dimensions shown outside grids to wall ends will also be deleted as obvious and thus retaining all dimensions between grids.
Many of you may already know this but thought worth sharing.
Cheers.
Nice! Now figure out how to automatically create dimension plans! Go... ?
GL
Trent Best
Best Systems
the.tabest@gmail.com |
Dimensioning grids |
Thu, Sep 21, 2006 at 9:50:34 AM
Grids at an Angle in Plan don't display in Elevation |
Thu, Apr 26, 2012 at 2:44:38 PM
Revit Architecture 2012 - Column Grids not Parallel to View will not show up |
Wed, Nov 23, 2011 at 1:27:06 PM
grids in 3D view |
Fri, Dec 17, 2010 at 11:08:31 AM
Grids |
Fri, Aug 3, 2007 at 11:44:57 AM
Members: | 2030582 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
