51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Cavity wall for Revit 2008
Wed, May 25, 2011 at 8:27:01 PM | Cavity wall for Revit 2008
shnip
Hello there,
I am new to Revit, love it but just want to know how to make a cavity wall that is 2 x 110 walls with a 50mm cavity.
Thanks heaps in advance
Jason
Thu, May 26, 2011 at 3:46:01 AM | Cavity wall for Revit 2008
4 Stars: 203 Votes
You can create that in several ways, you can use an "In-Place" family in your project in category "Walls" then create the "Void" where you want and use the "Cut Geometry" tool to cut the wall, or, you can create a "Face Based or Wall based" family to do that...
Thu, May 26, 2011 at 12:06:43 PM | Cavity wall for Revit 2008
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I don't have 2008, and that may be a problem. I have done similar, with my masonry walls, just set the parts up on wall editor. You have just one wall to draw and not the additional fooling around. Also doors and windows cut the wall just fine.
Edited on: Thu, May 26, 2011 at 12:08:29 PM
92654_CavityWalleditassembly.png92654_Cavitywallsection.png92654_CavityWallrealisticperspective.png
Cavity Wall - Cavity Not Filled
Mon, Jun 16, 2008 at 5:42:39 AM
Cavity Wall Around Bay Not Showing Correct Detail
Sun, Jan 17, 2010 at 3:50:14 PM
cannot get rid of lines join cavity in wall
Fri, Sep 12, 2008 at 8:31:30 AM
Joining different Cavity walls
Mon, Jan 5, 2015 at 12:26:44 PM
Column in a cavity wall
Wed, Oct 24, 2007 at 4:55:45 PM
Page generation time: 2.1395
