95 Users Online (93 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> No auto-route solution was found.
Wed, May 25, 2011 at 10:35:23 AM | No auto-route solution was found.
tmassey
tmassey Avatar
Any ideas? I have looked everywhere. i have modified the ducting and connections to suit and I still get this error message.
Using Revit Architecture 2012
Wed, May 25, 2011 at 11:21:32 AM | No auto-route solution was found.
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I have gotten that message numerous times in fact if you are not in the direct north south east west axis, the connection never seem to work. What I do is to create a work plane for the particular piping or duct work in question and proceed there. If you name the workplane. Then the framing elevation will snap to it.
Hope this helps
Thu, May 26, 2011 at 7:55:07 AM | No auto-route solution was found.
tmassey
tmassey Avatar
Thank you for both of your posts. I will try that this morning. Have a good day.
Pipe Auto-Route
Thu, Feb 9, 2012 at 1:28:42 PM
MEP
Thu, Oct 29, 2009 at 8:17:05 PM
Revit MEP
Wed, Oct 28, 2009 at 10:10:40 PM
Revit mep
Sat, Mar 24, 2012 at 4:03:14 PM
MEP QUERY - Sprinkler system showing route in angle
Tue, Mar 3, 2009 at 10:02:18 PM
Page generation time: 8.1815
