Forums >> Revit Building >> Technical Support >> Going from a Revit 2012 file to an older version of Revit
3 Posts No Rating |
Hey!!
I am a student and have minimal understanding of Revit. I have modelled my assignment in Revit 2012 on my laptop and need to print it from another computer. The computers at uni have 2011 and they won't open my 2012 file!!! GRR! And I haven't worked out a way to save a Revit view in PDF. Is there a way of downgrading my file to 2011 and/or saving to as a PDF?!
Thank you for your help!
Claire
downgrading your revitfile is not possible.
i would suggest:
- you cant save to pdf file, use cutepdf writer to print to pdf file,
- or export a dwf. (if the computer has a dwf viewer, as it should )
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
export IFC?
yep, there is no way to backsave.
Printing to PDF is very easy, and would be your best bet. It's the exact same process as a physical print-job.
3 Posts No Rating |
Thank you so much for your advice, and the heads up about CutePDF. All of your replies were very helpful
Push your school to upgrade, I'm sure they are on a subscription equivalent, and thus should be able to run 2012 at this moment...
Trent Best
Best Systems
the.tabest@gmail.com |
This is a good point. There's also no reason the school can't also run two versions, to give the students a little bit of leeway. I know our subscription allows us to run versions back to 2008.
Help opening older version of Revit file |
Wed, Mar 18, 2009 at 11:55:49 AM
Are people still using older versions of Revit? |
Sat, Aug 29, 2015 at 12:49:18 AM
Origin of the word Revit? And how do "save as" to older version of Revit? |
Thu, Sep 11, 2014 at 2:20:31 AM
Saving |
Sat, Jan 20, 2007 at 11:55:54 AM
What to do when an office you are working with is using an older version |
Tue, Jul 1, 2008 at 4:40:21 PM
Members: | 2098097 | Objects: | 23164 | Forum Posts: | 152290 | Job Listings: | 3 |
