73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> 3D-View only one floor
Thu, Nov 17, 2005 at 4:34:57 AM | 3D-View only one floor
spiekermann
Hello together, is it possible to show (and work in) only one floor of my (three floors high) building in 3D-View? What have I to do? Christoph
Thu, Nov 17, 2005 at 6:37:10 AM | RE: 3D-View only one floor
krmccurdy
In the 3-D view turn on the scope box (right click, it's under view properties). Just use the handles to crop down to the floor you want to work on in 3D. If you want a view for each floor, just create new 3D views and crop as required for each floor.
Thu, Nov 17, 2005 at 7:39:19 AM | RE: 3D-View only one floor
jfurlong
you could also try using worksets and placing all objects from each level into a workset, not perfect but can work
Thu, Nov 17, 2005 at 11:28:16 AM | RE: 3D-View only one floor
TomDorner
4.5 Stars: 25 Votes
An easier way to get the view is: 1. Copy the default 3D view (right click on view and choose copy) 2. Active new 3D view 3. From the menu choose: 'View' 'Orient' 'To other view' and then choose your floor plan view name You will then have a section box around your floor based on your View Range settings of the view you told Revit to Orient to. You can always adjust the section box further by dragging the blue grips as stated above. HTH Tom
(Dumb question) Can't see first floor when in second floor view [Revit 2015]
Thu, Jul 16, 2015 at 6:11:13 PM
Setting the View for Floor Plans
Sun, May 20, 2007 at 8:26:43 PM
FILLED REGION IN 3D VIEW OR PERSPECTIVE VIEW
Wed, Jan 26, 2011 at 5:10:05 PM
Turning floor surfaces off for individual floor elements?
Thu, Jun 29, 2006 at 1:31:20 AM
Ground Floor info. appearing on Second Floor
Thu, Jun 9, 2016 at 2:24:40 PM
Page generation time: 2.9168
