49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Monolithic Stair Question
Wed, May 25, 2011 at 12:42:29 AM | Monolithic Stair Question
RevPDX
I am spinning my wheels to create a monolithic stair with triangular corner segments (overall shape like a trapezoid).  Any suggestions?
Wed, May 25, 2011 at 11:47:06 AM | Monolithic Stair Question
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
do a sweep
Wed, May 25, 2011 at 12:11:04 PM | Monolithic Stair Question
3.5 Stars: 395 Votes
This is easy and you don't need a sweep.  Just sketch your treads and boundry in that shape.
Read this in your HELP: Creating Stairs by Sketching Boundary and Riser Lines
Wed, May 25, 2011 at 8:11:27 PM | Monolithic Stair Question
RevPDX
WWHub - I like your suggestion but am struggling to find the thread you mentioned.  Can you walk me through the process?  I keep getting a grumpy Revit message that my stair must have more than 2 boundary lines.
Thu, May 26, 2011 at 5:12:26 AM | Monolithic Stair Question
newrevituser
I think one way to create the pyramidal stair is from WWHub.
I created the pyramidal stair with 3 stairs with different shapes, which pointing to the top of the pyramid (see attached snapshot).  However, you have to be aware on the stair corner (or junction / collision).
Hope it helps.
Thu, May 26, 2011 at 7:14:39 AM | Monolithic Stair Question
Search your HELP using stair as your search word.    You will see the Creating Stairs by Sketching Boundary and Riser Lines listed in the search results.
CAN'T MAKE MONOLITHIC STAIR
Fri, Feb 5, 2016 at 10:16:18 AM
13
Monolithic Stair with Stringer
Wed, Aug 5, 2009 at 10:43:24 AM
Curved monolithic stair problem
Thu, Mar 11, 2010 at 2:33:31 PM
Monolithic stair - large construction height error
Thu, Oct 13, 2011 at 12:10:33 PM
Monolithic stair PROBLEM
Sat, Feb 9, 2013 at 8:14:32 AM
Page generation time: 0.6653
