27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Revit Topography doesnt follow CAD import
Tue, May 24, 2011 at 9:29:49 PM | Revit Topography doesnt follow CAD import
Tellis
Hey,
apologies if this is the incorrect section to post this but it seemed ok when i looked at the other topics.
I have a block of land we are developing for a University project, it was created in CAD and a single elevation was set as we wanted the block to be flat.
i followed these instructions on how to do it:
http://bim.wikispaces.com/file/view/Landiak+BIMWiki_Creating+Topography+from+CAD.pdf
but when i finish mine, the topography surface doesnt follow the block, insted of following the curve around, it just creates a straight line which skips all the points.
iv attached a file, so hopefully it works, but i want the area to only follow the highlighted blue line which was the imported file, not the grey section that is outside of the line.
can anyone offer some assistance please, iv searched google and spent an entire day attempting to solve it but so far nothing Sad
thanks
Tue, May 24, 2011 at 9:34:12 PM | Revit Topography doesnt follow CAD import
Tellis
ok so it appears the attachment diddnt work, heres a photobucket link
http://i122.photobucket.com/albums/o241/trommie/revit.jpg
thanks
Wed, May 25, 2011 at 6:58:06 AM | Revit Topography doesnt follow CAD import
It will take you awhile to understand Revit's site import process.
First thing you should learn is that Revit's contours will not usually be the same as the CAD contours.  This doesn't mean anything as far as the site goes.  Countor lines are really arbitrary and any two drafters might draw them differently in some areas.
Revit has rules on how to interpret and triangulate the site between points.  The more points provided, the closer Revit's site might look like the CAD import.  So for a typical polyline CAD site, the points provided are at the nodes on the polyline and nothing inbetween.  Thus Revit might interpret and draw the contour lines differently.  HOWEVER, the model will have the correct elevation at each of these points.
So, if you need to adjust the site because the CAD drawing was not adequate, then just add more points.
Wed, May 25, 2011 at 11:38:27 AM | Revit Topography doesnt follow CAD import
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
WW's comments are right on. The "CAD" drawing which you are comparing the revit drawing to is not necessarily correct either. However, that said, the contour lines are very specific and if you think that the "CAD" drawing is more accurate than the Revit one ( I don't ) then you can manipulate the surface to move the contour lines to more closely match the lines on your cad drawing. I am an engineer, and have had some experience with the situation you are describing and if you are required by a superior to match the contours or you feel compelled to match the "CAD" drawing then what I do is set a point elevations just below and above in elevation of the contour in question and then you can move it to adjust the contour line.
Creating a topography from 3D CAD survey import
Thu, Feb 23, 2012 at 7:53:02 AM
kerb to follow topography
Fri, Aug 21, 2009 at 6:25:29 AM
import cad
Thu, Dec 8, 2016 at 5:06:18 PM
3D CAD to Revit
Wed, May 4, 2011 at 7:59:52 AM
View linked CAD file on top of Topography
Mon, Nov 19, 2012 at 10:52:17 PM
Page generation time: 2.1125
