74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Exporting Solid Models from Revit to AutoCAD
Mon, May 23, 2011 at 9:57:27 AM | Exporting Solid Models from Revit to AutoCAD
zubsid
I am having issues exporting solid models from Revit Architecture 2010 to AutuCAD Architecture 2010. Whenever I try to export a model from Revit, it comes up as a poly mesh model. Is there a way to export it as a solid model?
Also, is it better to export Architectural models directly to AutoCAD or is it better to export it to IFC and then convert it into a DWG so that it retains th information?
Mon, May 23, 2011 at 12:41:08 PM | Exporting Solid Models from Revit to AutoCAD
4 Stars: 203 Votes
Because you are exporting that with "Polymesh" and not with "ACIS" solids.
Edited on: Mon, May 23, 2011 at 12:41:21 PM
Mon, May 23, 2011 at 12:52:04 PM | Exporting Solid Models from Revit to AutoCAD
zubsid
I did export the model as ACIS Solids; but it is still showing me the wire frame model in AutoCAD.
Wonder what I am doing wrong here.
Mon, May 23, 2011 at 12:58:48 PM | Exporting Solid Models from Revit to AutoCAD
4 Stars: 203 Votes
Well, I don't have any problem with that, just change your "visual style" like you want...
Solid Body Text for File Export
Wed, Sep 14, 2016 at 9:34:33 AM
Trouble w/ exporting to AutoCad
Thu, Jan 20, 2011 at 11:18:07 AM
exporting to autocad
Fri, Aug 31, 2012 at 7:35:41 AM
Thu, Jun 20, 2013 at 1:24:08 PM
Exporting revit to autocad with plotstyles.
Mon, Aug 14, 2017 at 11:01:29 AM
Page generation time: 1.8121
