Forums >> Revit Structure >> Tips & Tricks >> Sexy Families
167 Posts No Rating |
Happy Long weekend. I am creating millwork families in 2009 for our building model. How can I make the doors on my millwork cabinet open as they would with a regular door in Revit at 45 or 90 degrees.
cheers
Using Revit Architecture 2012 |
lol, harder, yet easier than you'd think. Your going to need an angle parameter, a reference plane for the face where the door would close flush to, and a reference line for the door... Prior to drawing in geometry, draw reference plane to represent face of cabinet, then draw a reference line at an angle to the reference plane, then create an angular dimension, and set it to be a parameter. constrain the end of the reference line which is closest to reference plane to the reference plane. Now flex your model, give it different values, and make sure that the "door" opens as it should. Once you have the skeleton flexing like you'd want it to (be sure to go higher, and lower than actual values you expect to ensure your family is valid thru all values). Once it is flexing like you want it to, then you draw in the geometry, and be sure to align & Lock the door geometry to the reference line so that it rotates (also pick the reference line as the work plane for the door geometry).
GL
Trent Best
Best Systems
the.tabest@gmail.com |
there are examples in the download section that you can use to get started.
Edited on: Fri, May 20, 2011 at 1:36:43 PM
Thank you very much. I will give that a crack now. enjoy the weekend
Cheers
M.Trevor Massey
Petroff Partnership Architects
Markham, Ontario
Just to expand on thetabest's post, you're probably going to find that it will work better to create a separate family for the door and nest it in the cabinet family. Also, to clarify use a ref LINE not a ref PLANE for the door angle.
How do I create an angle with a parameter
Sorry I meant to say how do I make my angular dimension into a parameter. My apologies if this is a Barney Fife question.
Trevor
Download the families guide from the AutoDESK site. That will really help you understand the process.
cheers
10 New REVIT 8.1 'Families' Video Tutorials released |
Tue, Oct 2, 2007 at 12:39:43 PM
Edit Default Families |
Sun, Jan 24, 2010 at 8:23:42 AM
Revit Families |
Fri, May 24, 2013 at 4:23:33 PM
12
Replacing Multiple families in a Project. |
Mon, Oct 15, 2018 at 10:34:29 AM
Rendering Families in Revit 2010 |
Mon, Jul 19, 2010 at 5:39:45 AM
Members: | 2101392 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
