37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Shared Parameters as part of a Foundation Slab
Thu, May 19, 2011 at 2:44:33 PM | Shared Parameters as part of a Foundation Slab
krunung
I'm pretty sure I know the answer to this question but does anyone know of any way to add a shared parameter to a foundation slab? It seems that with it being a system family, the option is not available. Is that the long and short of it? Any workarounds?
Thanks,
Kris Runung
Project Manager/Engineer
McClone Construction Co
Wheat Ridge, CO 80033
Thu, May 19, 2011 at 3:14:50 PM | Shared Parameters as part of a Foundation Slab
You can add shared parameters to system families at the project level.  Manage tab, project parameters / add then pick the category for the parameter and the shared parameter.
Thu, May 19, 2011 at 5:55:04 PM | Shared Parameters as part of a Foundation Slab
krunung
Ah yes. But we're still not given the option to set said shared parameter to any particular value, are we? Via formulas or otherwise? I guess the question ultimately becomes, besides adding text parameters, how does one modify the values of a dimensional shared parameter that has been added to a system family? Ultimately, I'd like the shared parameter to utilize actual reported values from the object being tagged to report another value. This would just be the start of the process but I don't even know if the first step is possible (or I suppose it's the second at this point).
Thanks,
Kris Runung
Tue, Jun 7, 2011 at 5:37:47 AM | Shared Parameters as part of a Foundation Slab
emgeeo
3.5 Stars: 7 Votes
Revit is kind of stupid in this regard.
For example, I cannot schedule or tag wall heights.  I cannot tag deck thickness.  I cannot tag wall thickness.  I can tag Bearing Elevations for footings, but not TFEs.  The list goes on.
Someday.
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
Foundation walls / vs slab edge sweeps
Wed, Nov 8, 2006 at 6:10:43 PM
sloped foundation slab to flat slab join
Mon, Mar 25, 2013 at 8:01:59 AM
Mid slab foundation thickening
Tue, Jul 31, 2012 at 7:58:11 AM
Slab Rigid Insulation
Wed, Nov 21, 2007 at 7:49:37 AM
Page generation time: 0.6733
