35 Users Online (34 Members):
Forums >> Revit Building >> Technical Support >> Structural Members not showing up in any view- Revit Arch 2011
5 Posts No Rating |
My model was working fine, but all of a sudden structural members are not visible in any view- trusses, beams, and columns will not show up in plan, section, or 3d. I have the detail level set to fine, and made sure that everything was selected in visibility graphics override. HEEELPPP!
Check your Discipline settings in the view properties and try coordination.
Is this a linked model?
Did you check your VG settings - click the show all so that you can see structural properties.
5 Posts No Rating |
Thank you for your reply! Unfortunately, none of those solutions worked- not view properties, vg, discipline or even phase properties and not a linked model. The structural systems are still in the model, because if I drag my mouse over the model, they highlight, but once I deselect, they disappear.
Any other suggestions? I have attached a screenshot in case that helps. This is a major problem that I need resolved ASAP- Big deadline. Thanks!
Revit 2012 Truss System (framing members not showing) |
Wed, May 9, 2012 at 9:25:33 AM
Structural Elements in Revit Arch not showing correctly |
Thu, Apr 9, 2009 at 5:38:27 PM
Sloping Structural Members |
Sun, Jan 9, 2005 at 5:32:40 PM
Curved structural members?? |
Tue, Apr 6, 2010 at 11:35:56 AM
Structural Members in Revit |
Tue, Jan 20, 2009 at 6:58:51 PM
Members: | 2019209 | Objects: | 22958 | Forum Posts: | 152182 | Job Listings: | 3 |
