100 Users Online (97 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Editing Revit Lighting Fixtures
Wed, May 18, 2011 at 10:58:38 PM | Editing Revit Lighting Fixtures
Harnk002
Hi all,
I'm relatively new to revit so this may be a silly question but does anyone know if it's possible to edit a revit family (fluorescent lighting fixture) to make it narrower?
Thanks in advance.
Thu, May 19, 2011 at 12:41:02 AM | Editing Revit Lighting Fixtures
Sven
3.5 Stars: 3 Votes
naturally, and you can even create your own! Just 'edit family' and then make the required amendments - then save it as a new family of your own... try it! If you get stuck, post your specific problem...
Fri, May 20, 2011 at 12:13:42 AM | Editing Revit Lighting Fixtures
Harnk002
Hi Sven,
Thanks for your help. I've managed to get that far before but I tend to find that it doesn't let me edit it properly. I can change the size/scale of some things but not the entire object. To be more specific i'm trying to essentially cut a 2x4 parabolic troffer light in half so that it becomes 300mm wide rather than 600mm. Any suggestions?
Thanks
How to show lighting fixtures on floor plan
Mon, Nov 6, 2006 at 10:15:39 PM
create a new lighting fixtures
Fri, Aug 15, 2008 at 10:54:55 AM
Revit MEP 2010 copy/paste lighting fixtures
Sun, Feb 16, 2014 at 12:46:35 AM
Lighting fixture problems
Wed, May 10, 2017 at 9:52:10 AM
13
Lighting Fixtures
Thu, Apr 24, 2014 at 6:13:27 AM
Page generation time: 5.0331
