41 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Tips & Tricks >> Open Bond
Wed, May 18, 2011 at 3:17:41 PM | Open Bond
ralexjordan
I need to make an open bond wall. Im trying to figure out what is the easiest way to make it. a new family, edit profile, etc.
any suguestions would be appreciated.
Wed, May 18, 2011 at 3:43:54 PM | Open Bond
I would probably do an in-place void family for each wall elevation.  One per wall.  See this thread:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=23757
That void cut can be full depth so that the pattern shows from both sides.
Edited on: Thu, May 19, 2011 at 6:38:20 AM
Thu, May 19, 2011 at 6:31:36 AM | Open Bond
coreed
coreed Avatar
4 Stars: 16 Votes
If this is going to be a free-standing wall of only masonry and you need to see the patten from both sides then i would use edit profile.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, May 19, 2011 at 11:01:40 AM | Open Bond
ralexjordan
i tired the 1st solution and the void was having a lot of problems cutting the plane.
i decided to just make a mass as a group and then array it along the wall. but that wasnt very editable and it bogged down my computer.
so i tried the second solution, and it looks great
Custom Running Bond Brick Pattern
Fri, Aug 26, 2016 at 2:38:25 PM
4’ x 8’ running bond hatch.
Thu, May 8, 2008 at 7:02:50 AM
A Rebar/ Bond Beam Family Question
Mon, Nov 5, 2012 at 7:08:20 AM
Ceiling grid hatch
Tue, Apr 30, 2013 at 2:23:08 PM
.pat file - running bond with angled tiles
Thu, Mar 30, 2017 at 6:28:09 PM
Page generation time: 0.3933
