58 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> grating
Wed, May 18, 2011 at 9:57:19 AM | grating
fenderbass
fenderbass Avatar
Does Revit Structure have a family for bar grating? I cannot find it. I need grating for platforms.
Thanks
Wed, May 18, 2011 at 11:39:01 AM | grating
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I have made several of them this is Grating Pacific FRP
Wed, May 18, 2011 at 11:42:12 AM | grating
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Sorry,
File was too big. Here is a view.
Wed, May 18, 2011 at 12:54:08 PM | grating
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I had to do a large walkway of grating once, and I modeled it.  It absolutely killed my computer.  I ended up using a semi-transparent floor material with an appropriately sized model hatch, and it looked pretty snazzy.   It wouldn't render as grating, however, if that's primarily what you're looking for.
Fri, Jun 15, 2012 at 12:16:41 PM | grating
flashbo
@ mbsteve,
did you ever end up putting that grating on the site? I could use that for Revit 2011.
Fri, Jun 15, 2012 at 12:38:25 PM | grating
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
The picture below is a T shaped pultrusion modelled after Grating Pacific, T1215
Fri, Jun 15, 2012 at 1:12:33 PM | grating
This is the built in material called "Wood Stockade" applied to both sides of this 1-1/2 inch wall.  I did not set any transparancy to the material - no need to and you can see through it in renders.  NOT IN NORMAL VIEWS
Fri, Jun 15, 2012 at 1:40:31 PM | grating
BTW - If you do a material like this, you can still set it transparent with a pattern for non-rendered views.
Fri, Jun 15, 2012 at 1:54:53 PM | grating
flashbo
Those are both great! I'm actually after the FRP type, that you had posted a picture of first. Did you happen to upload the revit file earlier? I did a search & couldn't find it.
Wed, Dec 11, 2013 at 8:04:17 AM | Bar Grating
jeffgroof
Bar Gratings are made from metal bars that cross each other or metal bars with filler strips welded to the metal bars. Metal grating can be assembled with cross-pieces fitted into joints of the other members or welded together at the intersections. The outer edge of the grate is enclosed by a metal frame. Bearing bars are the stronger bars used in the grating. They cover the entire span or length of the grate. Filler strip or cross-bars range from equal size to much smaller than the bearing bars.
Bar Grating
Wed, Dec 11, 2013 at 8:15:54 AM | grating
#11
jeffgroof,
I believe most of us know what bar grating is but maybe this will help some.  For your information, not all gratings are metal and not all gratings have the same configuration as you suggest.  An example of that would be the fiberglass gratings on the site you posted.
Stair Grating
Mon, Feb 27, 2012 at 7:49:27 AM
Steel grating treads
Thu, Oct 17, 2019 at 1:26:00 PM
How to add a void through a family
Tue, Apr 9, 2013 at 8:02:12 PM
How to model a steel grate floor
Mon, Apr 29, 2013 at 11:57:24 AM
Editing viod sweeps
Thu, Nov 20, 2014 at 9:11:08 AM
Page generation time: 0.8976
