26 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Trouble Turning On/Off DWG link
103 Posts No Rating |
When I use the hide command to turn off a DWG link, I cannot get it back. I use the Reveal Hidden Elements button to visually retrieve it, but it turns up missing. So then, I check Visibility Graphic Overrides to make sure that the DWG link is checked on, but it still does not show up. How can I retrieve my hidden dwg without having to re-insert the file?
I think I figured it out. The DWG is underneath my topography which is also turned off which would explain why it is not visible. I thought I already took care of the wireframe display settings before I used the Reveal Hidden Elements command, but then I realized that you have to enable the wireframe while in the Reveal Hidden Elements command, not before.
Revit link dwg issues |
Mon, Jul 1, 2013 at 8:09:19 AM
Link Cad issues |
Tue, Aug 5, 2014 at 11:28:03 AM
import/link, manage links... |
Tue, Apr 1, 2008 at 11:46:16 AM
Creating Turning Veins |
Tue, Apr 21, 2015 at 6:29:38 PM
Revit Mass Family - DWG import - the "Link" checkbox grayed out... ?! HELP |
Tue, Jan 9, 2007 at 5:34:28 AM
Members: | 2025973 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
