72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> text in family not display in schedule, fields blank in properties diaglog
Tue, May 17, 2011 at 3:24:06 PM | text in family not display in schedule, fields blank in properties diaglog
tbonebanjo
tbonebanjo Avatar
I just edited a water heater family in the model, added parameters for various data.  I made a new mechanical equipment schedule and filtered by type mark.  I clicked on the water heater and the properties dialog box under text has all of the fields I entered in the family editor, but the data is blank.  The only way these seem to show up on the schedule is if I manually type them in again......
Edited on: Tue, May 17, 2011 at 3:44:57 PM
Tue, May 17, 2011 at 3:30:21 PM | text in family not display in schedule, fields blank in properties diaglog
Read this topic in your HELP:> Shared Parameters
Then you will also have to read how to create them in your shared parameters file.
Come back if you have problems.
Tue, May 17, 2011 at 5:10:46 PM | text in family not display in schedule, fields blank in properties diaglog
thetabest
thetabest Avatar
3 Stars: 2 Votes
when you loaded the family into the project, it gives you a message saying you are about to overwrite the current family, and gives you two choices, the top one preserves any data that you already have established or modified in the project, whereas the 2nd choice (the bottom one) allows you to override all changes and restore the family to "out of the box".  I think this might be why you didn't get your data, if you clicked the top choice, and the parameters were empty in the project, then they would remain empty, try again using the bottom choice (be forewarned that this will set the types to be exactly as they are in the family editor...)
GL
Trent Best
Best Systems
the.tabest@gmail.com
Tue, May 17, 2011 at 6:29:13 PM | text in family not display in schedule, fields blank in properties diaglog
TKennedy
4 Stars: 7 Votes
thetabest is correct with one exception, selecting 'Overwrite the existing version and its parameter values' will only affect type parameters, instance parameters will be left alone.
Schedule Problems : Deletes modeled items when I delete blank fields
Tue, Sep 2, 2014 at 3:44:47 PM
Multiple dimension fields in schedule
Wed, Aug 24, 2011 at 4:31:08 PM
Door Schedule Problem - All Room Fields are Blank
Thu, May 30, 2013 at 7:40:46 AM
Editing Text In Schedules
Fri, Feb 17, 2012 at 2:47:33 PM
Titleblock text
Mon, Mar 27, 2006 at 4:15:19 PM
11
Page generation time: 1.5553
