60 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> 4" Rubber base in interior elevatiosn
9 Posts No Rating |
Hello. I'm on Revit 2011. I need to show 4" rubber base in all of my interior elevations. I thought maybe adding it to the wall assembly was good, but was unsure if this was the best way and I also don't know how to add it to the wall assembly!?!
Also, in the restrooms, I'll need to show an FRP wainscot that I'm hoping will be the same process as the rubber base. Thanks for your help!
make sure you review this thread before you make your decision:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=23005
4" Rubber Base |
Wed, Feb 20, 2013 at 12:26:21 PM
Add "grouting" between a flat wide base and angled narrow top |
Sat, Mar 13, 2010 at 7:40:32 AM
Wall Base/ Wall Sweeps and Door "Clipping/Cutting" RVT 2014 |
Fri, Jul 8, 2016 at 12:35:14 PM
"Painting" Interior Walls |
Tue, Dec 11, 2007 at 8:27:47 PM
wall base visibility in plan |
Sun, Apr 15, 2007 at 7:36:55 PM
Members: | 2030567 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
