74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Revit won't start again (i have to restart)
Thu, May 12, 2011 at 6:29:10 PM | Revit won't start again (i have to restart)
koneskizoran
I have a problem with starting revit again, when i close it i can't start it again. I have to restart windows to get back revit. Thats happaning with Revit Architecture and Revit Structure. And it is same with Robot structural Analysis and AutoCad. Does anyone have clue whats wrong?
We are using Windows XP 32-bit system.
Thanks
Fri, May 13, 2011 at 3:43:42 AM | Revit won't start again (i have to restart)
4 Stars: 202 Votes
I believe the problem is your System/machine and not Revit, you said you are using Windows XP 32 bits but what about the rest? system specs.? Ram, Processor, revit version???
Fri, May 13, 2011 at 1:36:35 PM | Revit won't start again (i have to restart)
koneskizoran
Revit version 2011 (Architecture and Structure)
I am using laptop Asus - X52S
Operating system: XP 32 - bit , SP3
CPU Type   Mobile DualCore Intel Core 2 Duo T5450, 1666 MHz (10 x 167)
System Memory   3072 MB (DDR2-667 DDR2 SDRAM)
Video Adapter   NVIDIA GeForce 9300M G (512 MB)
Fri, May 13, 2011 at 4:31:16 PM | Revit won't start again (i have to restart)
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Check the link below, revit won't start. I found that deleting the WSCommCntrData.XML file worked a miracle. This is the likely suspect and I have spoken to Autodesk and they assured me the program would be fine with out.
Fri, May 13, 2011 at 4:32:04 PM | Revit won't start again (i have to restart)
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I did not have this problem with 2012 but with 2011.
Fri, May 13, 2011 at 8:34:50 PM | Revit won't start again (i have to restart)
koneskizoran
Only thing with WSCommCntrData i found in registry:
Type:REG_SZ
Data:WSCommCntrData
should i delete from there?
Fri, May 13, 2011 at 8:58:25 PM | Revit won't start again (i have to restart)
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I think that is what I did, last year. You will have to get rid of them from each program so should be 4 of them.
Sat, May 14, 2011 at 6:01:35 AM | Revit won't start again (i have to restart)
coreed
coreed Avatar
4 Stars: 16 Votes
the WSCommCntrData.XML file should be a physical file located on your computer harddrive.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, May 14, 2011 at 7:51:45 AM | Revit won't start again (i have to restart)
koneskizoran
I have just deleted file from harddrive (not from regestry). Didn't see second page in Revit Structure 2010 won't start!!! Help!!! tread.
And I have same problem:
I have no problems with working in Revit, but I can start it once, after closing it windows is doing normaly. When I start Revit for the second time i get freeze monitor with Revit application and I have to do "end task". I have to restart XP to get back in Revit application. (Same with Architecture, AutoCad, 3dsmax, RSA)
Thank you
Sat, May 14, 2011 at 7:57:56 AM | Revit won't start again (i have to restart)
coreed
coreed Avatar
4 Stars: 16 Votes
if you haven't already done so, clean out all your temp file folders etc.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, May 14, 2011 at 8:32:49 AM | Revit won't start again (i have to restart)
koneskizoran
Do you mean c/windows/temp ?
Sat, May 14, 2011 at 9:15:19 AM | Revit won't start again (i have to restart)
koneskizoran
I have never investigating temp folder.
I deleted all files (that i could delete).
Then 5 minutes didn't do anything and started revit. One new file in temp folder displayed (Perflib_Perfdata_ebc.dat). I belive that this is file that i need to delete, but i can't. I searched how to delete but i haven't find answers.
Sat, May 14, 2011 at 11:44:15 AM | Revit won't start again (i have to restart)
#13
koneskizoran
Every file from temp was deleted using unlocker and haven't help. Same thing again.
Tue, May 24, 2011 at 4:20:47 PM | Revit won't start again (i have to restart)
#14
heinzk1
OK this is not a solution to the crashing but somewhere to look to possibly be able to restart revit without a complete shutdown and restart.
I have a few software programs that will crash every once and a while and disappear from the Applications Tab under task manager but will still be active in the Processes.
So next time try going to the processes tab under task Manager and look for the program and end the process there if it shown.
Just something to look for,Heinzk1
Tue, May 24, 2011 at 4:45:46 PM | Revit won't start again (i have to restart)
#15
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
What I did was to use the windows search tool to find the file: WSCommCntrData.XML
As I recall the search tool located 4 of them in my software. I removed all for of them. Haven't had any trouble since.
revit won't start
Thu, Nov 3, 2005 at 10:50:46 PM
Revit Structure 2010 won't start!!! Help!!! [ 1 2 ]
Mon, Oct 8, 2012 at 11:20:43 PM
18
Revit Architecture 2008 does not start
Fri, Jul 27, 2007 at 1:59:04 AM
revit MEP 2016 won't open
Tue, Aug 15, 2017 at 9:58:04 PM
Problem during Installation in REVIT 2010... pls HELP (i'm new)
Tue, Jun 16, 2009 at 12:42:39 AM
Page generation time: 1.8512
