65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Unit Question?
Wed, May 11, 2011 at 11:12:07 PM | Unit Question?
SDSTUDEN
I was wondering if there was a way to change the default input feet to inches. I am used to AutoCAD and i dont use the ' or " mark i usually just type the amount of inches so it would be helpfull if i was able to do this in revit as well.
Thu, May 12, 2011 at 7:27:13 AM | Unit Question?
0 space number is the way you do inches only in Revit.  0 24 gives you 2'
Thu, May 12, 2011 at 8:30:39 AM | Unit Question?
SDSTUDEN
Thank you for your advise it is verry helpfull.
Thu, May 12, 2011 at 1:55:04 PM | Unit Question?
pchan
pchan Avatar
5 Stars: 5 Votes
there is a hotkey application developed by someone who posted it on AUGI. it is designed to input the inches instead of feet.
It is called inchworm, and it is a freeware.
Try google it and see if you can download it.
HTH
Thu, May 12, 2011 at 1:58:27 PM | Unit Question?
pchan
pchan Avatar
5 Stars: 5 Votes
Here is the link:
http://forums.augi.com/showthread.php?t=2870
You have to be a member of AUGI though
Multi Unit buildings
Mon, Jun 6, 2005 at 2:41:01 AM
Can a Linked file be tagged in a host project to indicate the unit Type?
Sat, May 15, 2021 at 4:12:22 AM
Revit Mechanical Equipment question VAV unit question
Mon, Oct 24, 2016 at 4:17:01 PM
Unit tolerance
Thu, Jan 21, 2010 at 5:12:11 PM
Door/Window tag to not display unit symbol?
Thu, Aug 18, 2011 at 3:44:55 PM
Page generation time: 0.6282
