173 Users Online (172 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> save a family
Wed, May 11, 2011 at 4:57:11 PM | save a family
SteveB
3.5 Stars: 5 Votes
I have created an in place family in r2012.  I want to save it for use in other projects.  command used...
File / saveas / library / family / family to save...
the "family" as listed in the browser does not appear in the "family to save" list.   How do I save this family?
Wed, May 11, 2011 at 5:02:57 PM | save a family
TKennedy
4 Stars: 7 Votes
I don't think you can save an in-place family like that. What you can do is start a new family of the same category, edit the in-place, then copy and paste from one to the other.
Wed, May 11, 2011 at 5:05:22 PM | save a family
thetabest
thetabest Avatar
3 Stars: 2 Votes
Create a new empty family of the same category as your inplace, in the same session of Revit, open your project and then enter the inplace editor, copy the whole thing, then paste into the previously created blank family, make the few adjustments, changes that you will have to do, then you should be good to go.
OR
Copy the inplace family, and paste it into the new project (both projects need to be open in the same session of Revit).
Trent Best
Best Systems
the.tabest@gmail.com
Wed, May 11, 2011 at 5:06:06 PM | save a family
SteveB
3.5 Stars: 5 Votes
i am pretty sure you can't copy / paste families between projects.   all that work is not re-usable???
Wed, May 11, 2011 at 5:27:21 PM | save a family
thetabest
thetabest Avatar
3 Stars: 2 Votes
This isn't copying from a project to a family, you are IN the in place editor, you are copying a family from a family, and I just verified it does work.  It won't get everything, i.e.- it might lose some parameters if you added any, but you can at least get all you linework, solids, voids, etc.
Trent Best
Best Systems
Thu, May 12, 2011 at 6:15:33 AM | save a family
SteveB
3.5 Stars: 5 Votes
You're right, I am asking the question wrong.  You can always go into a project, edit the family and choose to save it to a file, assuming one can remember in which project that family is located.  I thought I read that with r2012, one could simply open families (that are part of a particular project) without having to open it.
Save Drafting View as Family
Tue, May 12, 2009 at 9:44:37 PM
saving family in revit 7?
Sat, Aug 13, 2005 at 1:56:19 AM
Cant save, save as, print.......
Tue, Sep 10, 2019 at 6:24:45 PM
cant save my family.
Wed, Jul 25, 2012 at 9:56:34 PM
How to save family drawings to pdf file?
Thu, Aug 25, 2016 at 11:46:27 AM
Page generation time: 1.6019
