Forums >> Revit Building >> Technical Support >> Level-Head on linked Revit-file visible... puzzler.
26 Posts No Rating |
Heya all,
Kudo's to the brainiac who can solve this one:
I've linked a Revit model (steel staircase) into my project, and positioned it in place. On my sections and elevations of the staircase, both the main project-file's level-heads as well as the linked model's level heads are displayed. I need to remove the linked file's level-heads, so that only the main project file's levels are displayed.
The linked file's levels cannot be selected (to hide). I've hidden the level-heads withing the liked file, but they still display on the main project file. I've deleted the elevations etc. on the liked file, and they are still displayed on the main project file.
Anyone dealt with this before?
All linked files can be controlled through VG. Simply goto the Revit links tab, for this link, change the display settings to custom, pick the annotation category tab, change the setting from host view to custom and uncheck show annotation categories in this view.
Learn how to use these VG controls for linked files - very powerful.
Very powerfull indeedy!
Thanks, WWHub.
Family from linked file not visible |
Wed, Nov 18, 2015 at 12:16:19 PM
Room Tags not visible in a linked file - Revit 2014 |
Tue, Apr 4, 2017 at 5:54:05 PM
Help Needed: Unsolved Linked file Question |
Mon, Jul 9, 2012 at 4:32:30 PM
Linked Revit model not visible |
Fri, Aug 21, 2009 at 6:23:21 AM
Linked Revit Topography file displayed in hidden lines in 3d view main bld file |
Sat, Jul 7, 2012 at 3:38:17 PM
Members: | 2100607 | Objects: | 23171 | Forum Posts: | 152294 | Job Listings: | 3 |
