33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Masking Text in callout
Tue, May 10, 2011 at 10:35:46 AM | Masking Text in callout
ideaguy
ideaguy Avatar
Back to using revit after 4 years
Revit version 2012
Have wall section call outs to cad files that were inported. Need to reference. In the old days we would place referenced Revit sections on Dummy sheet and mask the callout text, then write in the correct sheet number.
Cant seem to get the masking region to cover text of callout.
Tried using hidden line, thin line ect ...
Is there a better way? Autodesk help menu is plain vinalla.
Tue, May 10, 2011 at 5:43:29 PM | Masking Text in callout
thetabest
thetabest Avatar
3 Stars: 2 Votes
Create a drafting view, place a text component in it (I make it say Placeholder, and the title of the detail).
Now create a sheet, place this drafting view on that sheet, give it the sheet number (in essence make an empty placeholder sheet with views).
When you create the callout/section, check the refer other view check box on the options bar, select the appropriate detail from above.
This is simpler than masking or any other kind of tweaking, and it doesn't increase your file size much!
Edited on: Tue, May 10, 2011 at 5:44:35 PM
Trent Best
Best Systems
the.tabest@gmail.com
Text Box Width Factor Masking Error
Wed, Mar 18, 2015 at 2:33:50 PM
Masking region at section callout head.
Tue, Jul 30, 2013 at 1:43:26 PM
Masking Regions in Symbols not working
Thu, May 7, 2009 at 5:47:00 PM
Interior Elevations - 4 callout bubbles combined to single callout bubble?
Wed, Jul 10, 2013 at 5:08:00 PM
Text Referencing a View
Tue, Dec 16, 2008 at 10:15:01 PM
Page generation time: 0.5079
