55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Why Revit for BIM on Residential homes
Mon, May 9, 2011 at 8:55:24 PM | Why Revit for BIM on Residential homes
bjames
Hello Guys, this is my first visit to RevitCity. I have to convince my Boss within the next month on the best BIM software for residential drafting moving forward. I'm currently going through the Trial versions of ChiefArchitect, Visionrez and Softplan. Although I think Softplan is the easiest to learn and produce working drawings why are the majority of forums online tend to still lean towards Revit Architecture. Can Revit do everything that softplan does for residential?
Any advice would be greatly appreciated.
Mon, May 9, 2011 at 11:19:49 PM | Why Revit for BIM on Residential homes
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
check this post ---> LINK
You will lose some time translating standars, and building the custom library  you need, but in long term you will be able to recycle a lot, or creating variations of the same families.
Tue, May 10, 2011 at 8:45:52 AM | Why Revit for BIM on Residential homes
jterrell
3 Stars: 5 Votes
Revit beats all other software you mentioned in its detailing capabilities and flexibility. However, having used Chief Architect, if I were in an all residential firm that specialized in homes that were not too 'cut up', and required details that were mostly drag and drop, I would pick Chief Architect.
Tue, May 10, 2011 at 11:10:11 AM | Why Revit for BIM on Residential homes
coreed
coreed Avatar
4 Stars: 16 Votes
if you decide to farm-out structral or mep they will probably be using Revit, not Softplan or CheifArchitect. i do like Softplan though. Most people use their history with Autodesk, that's why all the Revit Architecture.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, May 10, 2011 at 1:22:05 PM | Why Revit for BIM on Residential homes
thetabest
thetabest Avatar
3 Stars: 2 Votes
Unfortunately Revit, I'm not a big autodesk fan, mostly because they eat up and spit out all the little guys, but it is a very powerful tool.  It especially would excel at residential, you could model a subdivision, link in different floor plans, and generate your site layout plans from it... Then you decide one floor plan is selling better than others, you can easily go back, switch out some of the less popular floor plans with the more popular floor plans and the siteplan will automatically update... Of course you'd probably have to recreate the dimensions as they will probably die when you swhitch floor plans...  I would LOVE to do a subdivision in Revit, and the response to changes is phenomenal, especially with design options, typically with residential, you have different "Options" which the buyer can purchase, custom tailored site plans can be created simply, just modify which design options are purchased under manage links tab for that instance (be sure to name each instance of a house with it's lot # for ease of association and tracking).
Revit also gets rid of a lot of the housekeeping details, For example, create your cookie cutter default construction plans for a given floorplan, then when it comes time to apply to say a lot, just save as a new central file, go to project settings, change the project title to reflect the lot number, or however you name it, every sheet is now updated, you should then be able to print your construction documents, just select any design options and you should be good.
Trent Best
Best Systems
the.tabest@gmail.com
Thu, Nov 14, 2013 at 3:07:38 AM | Why Revit for BIM on Residential homes
Mike48
Hello Guys,
Building Information Modelling (BIM) tools Revit Architecture and Revit MEP are used to produce detailed 3D BIM models for a number of homebuilders.
Since Revit supports parametric 3D modelling, all the objects are responsive to changes made to other objects.  Some benefits include greater interoperability and collaboration, waste reduction, clash detection and risk minimisation, and increased cycle time.
Edited on: Thu, Nov 14, 2013 at 3:44:38 AM
Residential 3D BIM Modeling | Architectural 3D Rendering Services
 | Home Builder Construction Drwaings
Fri, Jan 13, 2017 at 12:42:18 AM | Why Revit for BIM on Residential homes
ChristianBale
I think following advantages gives you best possible answer so that you can understand why Revit for BIM on Residential Home important;
Advantages of BIM Services:
  • Produces exact amount departures
  • High caliber and exact documentation of the development procedure
  • Cutting undertaking cost by killing misuse of development material
  • Enhanced development administration and Empowers pre-creation of various segments of the development to minimize configuration time
3d bim modeling services bim consulting services
revit outsourcing
Residential BIM model
Wed, Jan 11, 2006 at 12:21:47 AM
REVIT Job - BIM Specialist - Cedarglen Homes - Calgary Alberta
Sun, Jul 8, 2012 at 2:34:32 AM
Introducing
Wed, Mar 17, 2004 at 5:11:59 AM
Looking for helpful info on which revit program to purchase?
Wed, Apr 14, 2010 at 8:51:01 AM
Revit Arch & Navis Applied to $500SF-$1100SF Custom HOMES
Thu, Oct 16, 2014 at 11:29:29 AM
Page generation time: 1.7398
