73 Users Online (73 Members):
Forums >> Revit Systems >> Tips & Tricks >> Complex Conduits
I need to figure out how to make a "rolling kick" as the guys in my company call it. What this is: Place a conduit at a given elevation, say 4'. Copy this conduit to a new height, say 0', then move it some distance in the x and y direction. What I need is to now be able to connect these two conduits with a conduit which takes the minimum path between (a straight line).
I've tried this over and over, but I can't let revit do it automatically, because it wants to drop down the 4' then path in a diagonal to the other conduit. It seems that I struggle with Revit whenever I try to create something which changes in all 3 axis.
I'll post a dwg for further clarification once I get my hands on one...
Thanks,
Trent Best
Best Systems
the.tabest@gmail.com |
trent,
Try creating a work plane through the centerlines of the conduits, name the workplane and then you can create a view using the framing view. then you can work in that plane. to create your connections.
Beautiful, slight adjustment to your process, had to make a grid line instead of a work plane (so that the framing view could snap to the grid). But then it worked!
THANKS!
Trent Best
Best Systems
If you name the workplane the framing view will snap to it. If you do not name the view it is ignored by the framing view.
draw conduits/pipes in Revit Architecture |
Wed, Feb 29, 2012 at 1:52:11 PM
Parallel Pipes and conduits |
Wed, Feb 29, 2012 at 3:48:12 PM
Modeling group of conduits from one separation value to another |
Wed, Aug 19, 2015 at 5:51:23 PM
Conduit Run with Fittings |
Thu, Sep 1, 2016 at 3:12:57 PM
Calculatiing Overall Length of Conduit in REVIT MEP |
Tue, Aug 21, 2012 at 2:35:24 PM
Members: | 2022280 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
