155 Users Online (153 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Section cuts WAAY too deep!
Mon, May 9, 2011 at 9:55:35 AM | Section cuts WAAY too deep!
DaveLowery
Everytime I cut an unreferenced section, the depth of the section goes all the way to the edge of the building and I have to zoom all the way out and pull it back closer.  I can't imagine why Revit would do this as a section through hundreds of feet of building does nobody any good!  HELP!
Mon, May 9, 2011 at 11:42:46 AM | Section cuts WAAY too deep!
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
In the section view you can change the far clip distance in the properties box. This is the same as manually adjusting the distance in the plan view or other sections.
Tue, May 10, 2011 at 7:25:04 AM | Section cuts WAAY too deep!
A building section by default will go the full depth of the model.  A wall section will only go a few feet.
Tue, May 10, 2011 at 12:46:00 PM | Section cuts WAAY too deep!
DaveLowery
OK...so how do I specify that I want a wall section?
Tue, May 10, 2011 at 1:03:04 PM | Section cuts WAAY too deep!
Your choice ... type ... when you create the section.
Tue, Jun 7, 2011 at 5:34:55 AM | Section cuts WAAY too deep!
emgeeo
3.5 Stars: 7 Votes
If you want the sections to default to the wall type, do the following.
1.  Create a new wall section (change before you place it)
2.  Select the wall section
3.  Use the create similar function (CS) or right click on the element
4.  Escape out of command
5.  Create a section with the section command, it should default to the desired type
Rouge sections cuts
Wed, May 2, 2012 at 4:07:32 PM
Multiple Section Cuts as duplicates
Thu, Dec 4, 2008 at 11:44:59 AM
Detail Cuts
Wed, May 3, 2006 at 5:03:48 PM
Phases and Section Cuts
Thu, Mar 19, 2009 at 9:49:27 AM
was given a central model, am unable to view any new section cuts
Wed, Mar 13, 2013 at 4:16:24 PM
Page generation time: 0.9039
