33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Animations - Solar Angles
Thu, May 5, 2011 at 5:09:19 PM | Animations - Solar Angles
Marquand
I would like to use shadows on my animations, but I noticed that when I do that, the angle of the sun moves with the angle of the camera. Am I doing something wrong? I just want the solar angle to remain unchanged during the length of the animation.
Thu, May 5, 2011 at 5:19:15 PM | Animations - Solar Angles
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
In your sun settings, you probably have the sun coming from the upper right, or something similar, so that's always relative to your camera.  You can create a single day still setting, and even give revit the latitude and longitude,  time of year and time of day for your shadows.
Thu, May 5, 2011 at 6:19:24 PM | Animations - Solar Angles
Marquand
That sounded pretty plausible, but as it turns out it was not the sun angle that was changing. As the camera moved, there was a clip distance at which point Revit no longer cast shadows. So it made it look like the shadows were declining. I am playing with the actual 'far clip' setting on the Views and that seems to affect it. Its odd; even though the shadows were well withing the far clip distance, shadow casting seems to have its own far clip, which may be a percentage of the visibility far clip. So I just set far clip to a thousand feet and it seems to be working now.
Thu, May 5, 2011 at 6:52:23 PM | Animations - Solar Angles
itsmyalterego
4 Stars: 16 Votes
You can also just turn off far clipping--set it to no clip.  Unless you have a humongous site, this is probably preferable.
Solar Study Animations
Mon, Sep 14, 2015 at 4:10:23 AM
INTERIOR SOLAR STUDIES [ 1 2 ]
Wed, Oct 8, 2014 at 4:42:37 AM
23
Animated Solar Studies in Revit 9
Tue, May 26, 2009 at 1:00:58 PM
Solar study
Fri, Mar 13, 2009 at 11:59:45 AM
Solar Gain and Windows
Sat, Mar 10, 2007 at 8:12:43 PM
Page generation time: 0.4849
