62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> Rendering material doesn't show up
2 Posts No Rating |
Hi;
I have created a generic face based family and I have assigned material to it, but when I render, the material doesn't show up. any idea what is the problem. I am using Revit architecture 2012.
Thanks
![thetabest Avatar](user_avatar/231785.jpg)
![3 Stars: 2 Votes](/images/stars_3.gif) |
First what shows up? 2nd, does your face based object extend beyond its host? If it is flush with its host, then the host will show up and the object won't... If your object is showing up, but the material is wrong, then you should adjust to another material, verify that the material has indeed been set (i.e.- if you have to edit the family to change the material, when you load the family back into the project, choose the bottom choice when it asks you to override). Without further details on what you are getting I can only throw out some common offenders.
Trent Best
Best Systems
the.tabest@gmail.com |
Families don't take materials while rendering |
Sat, Nov 28, 2009 at 3:22:05 PM
Material takeoff - the math doesn't jive |
Fri, Sep 8, 2006 at 11:04:29 AM
Material's render a different color |
Thu, Oct 20, 2011 at 8:08:58 PM
How do you add an imported material to Revit's material library ? |
Mon, Aug 16, 2010 at 8:06:17 AM
window opening doesn't show in floor plan view |
Mon, Oct 3, 2005 at 7:59:15 PM
Members: | 2017168 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
