Forums >> Revit Building >> Technical Support >> variable line radius
how do i make a sketch line with a variable radius?
third time trying to upload an image of the line i want to make..
Edited on: Wed, May 4, 2011 at 4:39:17 PM
The ellipse tool, standard for details lines and sketches, just use the slit element tool on it.
thanks myalterego- are you talking about making the line
into multiple segments with different radiuses? vs. one smooth
arch?
One smooth arch. What you've shown is half an ellipse. You also have splines as an option for lines, though they aren't acceptable for sketches, IE the path of a sweep.
If you want to model objects with spline-like curves, it's best to draw the path as a detail line, and build the path of your sweep/whatever over the top with arcs. Revit's handy curve-snapping makes this look pretty good, and the geometry is 100x more simple.
yes i traced those curves with a spline and made the extrusion-
but i would like a more accurate curve.. do you know of a way
to make a line- (detail or sketch)- that has lots of various radiuses
on it?
maybe some kind of formula with distance and radius or something..
okay forget that ellipse- this line i made with a spline but i need the
variable radius more accurate..
Edited on: Wed, May 4, 2011 at 5:44:23 PM
Edited on: Wed, May 4, 2011 at 5:46:08 PM
revit city software is so full of bugs anything only works half the time..
i'll try this image upload for the fifth time..
Get the Radius of a Circle (model line) |
Thu, Feb 9, 2012 at 9:12:58 AM
Need help creating a sloped slab with Radius Edge |
Tue, May 2, 2006 at 5:23:52 PM
Radius window jambs |
Fri, Jul 6, 2007 at 8:55:13 PM
How do you trim to a radius rather than a 90 degree corner? |
Tue, Sep 16, 2008 at 8:54:38 AM
11
Reveals & Sweeps Variable Height |
Wed, Aug 20, 2008 at 2:53:17 PM
Members: | 2126516 | Objects: | 23228 | Forum Posts: | 152296 | Job Listings: | 3 |
