74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Creating Complex geometry
Tue, Nov 15, 2005 at 11:59:56 PM | Creating Complex geometry
Macka
Is there a way to create blended solids or voids using different planes for the top and bottom? Alternately, is there a way to create a reference plane by allocating 3 points that would be on that reference plane? Attached is a file showing complex geometry using voids to cut away at a solid to create a specific shape. At this stage, it is incredibly hit and miss. If reference planes could be created by nominating 3 points on that plane, the desired shape would be so much easier to achieve!
Wed, Nov 16, 2005 at 2:59:36 AM | RE: Creating Complex geometry
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
True. This is a wishlist item. Most shapes are achievable but extra steps are required to achieve them as you've mentioned. It would be nice.
Families - Locking complex geometry
Thu, Dec 4, 2014 at 10:48:23 AM
Scheduling Coordinate Points for Complex Geometry
Fri, Jan 21, 2011 at 10:46:23 AM
3D Max to Revit for complex geometry?
Thu, Mar 17, 2011 at 3:05:44 PM
How do I use a geometry created in AutoCAD as a Revit Roof?
Fri, Oct 9, 2009 at 4:51:12 AM
Complex Revit Drawings
Wed, Feb 2, 2011 at 5:55:24 PM
Page generation time: 0.4534
