Forums >> Revit Building >> Technical Support >> Make imported image NON-SELECTABLE (not just pinned)
3 Posts No Rating |
Hello all,
I am working in Revit 2011. I have imported a sketch of a siteplan and would like to model over it. However I do not want the image to move. I know you can PIN the image, however it is still selectable. I would like to figure out a way to have it really like a background image, unselectable and pinned. This way I can drag and select only the model compents I am working on.
Thanks for all the help!
Jamie Straz, AIA, LEED GA Principal REINES & STRAZ, LLC ARCHITECTURE | INTERIORS | PLANNING 975 41st Street, Suite 407 Miami Beach FL 33140 C: 786) 218-3621 O: 305) 397-8779 F: 305) 675-8502 reines-straz.com AA26002849
My best advice is to learn to deal with this..... Learn to use your filter and pay special attention when selecting with a crossing. Hard rule to learn at first after coming from CAD but best if learned.
There is something you can do but I'll let someone else tell you if they don't agree with the above.
BTW - Turn off press and drag and that will help.
3 Posts No Rating |
Thank you,
The press & drag does help a lot!
Turn off "select pinned elements" (down right corner)
skaut,
You are right - that icon is now available in recent releases but it was not available in the 2011 or even 2012 release. Attached is an image of what was available in 2012.
The program keeps getting better.
oh, I am "only" four years late
Yes, it does keep getting better!
How make image not selectable |
Sun, Oct 15, 2006 at 3:19:04 PM
Why are pinned elements selectable? |
Fri, Dec 11, 2009 at 9:02:40 AM
imported images. Is there a way to "pin" them. |
Wed, Dec 10, 2008 at 3:55:49 PM
Pinned walls in 2014 can't UnPIN Walls |
Wed, Oct 15, 2014 at 3:33:18 PM
structural column member not selectable |
Wed, Jul 19, 2006 at 9:26:07 AM
Members: | 2116524 | Objects: | 23196 | Forum Posts: | 152302 | Job Listings: | 3 |
