75 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> Doors make a gray shadow in Sections
![sjs Avatar](user_avatar/1503.jpg)
![3.5 Stars: 10 Votes](/images/stars_3.5.gif) |
Every time that a sections pass in front of a door, the section display a gray shadow.
Enyone know how resolve this problem.
Note: Gray shadow in shading mode. White shadow in Hiden mode.
Tks.
admin
![hjacobs Avatar](user_avatar/2.jpg)
![3.5 Stars: 16 Votes](/images/stars_3.5.gif) |
what do you mean by shadow? Is it on your wall or something?
Hiroshi Jacobs
The Catholic University of America |
I have send you an email with some pictures.
admin
I think it's because your section is cutting through your door families. I have noticed the same problem with cutting through other families. What happens is if you have symbolic lines, they are considered part of the family so even though it may not look like it, you're actually cutting through it. try moving your section away from the door so that it doesn't cut through the swing.
Hiroshi Jacobs
Yes, i know is because the section cut part of the family, even if is just symbolic lines.
But sometimes i can't move the section line.
Well, i see there is no way to remove this gray shadow off the sections.
Meaby in a new release....
Tks any way.
Gray walls |
Tue, Jun 13, 2006 at 1:07:37 PM
Doors displaying as gray in Shading with Edges |
Thu, Aug 6, 2009 at 3:46:42 PM
shadow projection on walls |
Thu, Apr 14, 2011 at 2:29:41 AM
section view |
Thu, Nov 8, 2007 at 12:28:15 PM
Shadow density / weight |
Fri, Feb 6, 2015 at 12:47:56 PM
Members: | 2016908 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
