Forums >> Revit Building >> Technical Support >> Cad not importing correctly into revit
See image for cad vs cad imported into revit.
Any ideas what is going wrong?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
are you refering to the colors?
no :p
The lines are pread around in segments.
peace is the path."
Mahatma Gandhi.
try linking instead of importing and see if it has the same result.
It appears that the CAD "Lines" are not native lines but a defined line like lines with characters in it.
Importing CAD 3D |
Sat, Mar 7, 2009 at 7:26:46 AM
Importing CAD to REVIT (vs. 2014) |
Mon, Nov 24, 2014 at 4:03:44 PM
importing cad problem |
Fri, Mar 15, 2013 at 6:33:53 AM
Importing CAD Line Styles - Auto Convert? |
Thu, Jun 14, 2012 at 4:04:28 PM
Importing a cad file |
Fri, Apr 27, 2012 at 3:33:22 PM
Members: | 2102441 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
