29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Door family elements showing in plans
Sun, May 1, 2011 at 9:29:23 PM | Door family elements showing in plans
A5Len
I have created a sectional overhead door family. When I place it in my project plans the rails above the door head show in plan. There are 3 rails - the 2 side rails which are sweeps that run up the door jamb and then continue along the ceiling do not show correctly in plan ie part of rail below cut plane shows & the rest doesn't. However the central rail that only runs along the ceiling shows up on the plan. This rail is associated to a plane above the door head and does not protrude through the cut plane in the family or project. It is also not joined to any other elements.
I have previously had this issue with a roller door I created where the drum was always vissible in plan.
I tried playing with vissability settings however making it not vissible in plan also means it is not visible in RCP, so that doesn't help.
I have made plenty of custom doors in the past and have not had this issue
Anyone got any ideas?
Thanks
Door Swings in reflected ceiling plans
Sun, Nov 19, 2006 at 2:20:19 AM
Door family showing one thing in Family Editor another when placed into project.
Mon, Aug 24, 2009 at 3:24:33 PM
Low elements in a casework family showing up in RCP (Revit Architecture 2012)
Tue, Feb 5, 2013 at 1:42:21 PM
linewidth of elements in family editing
Wed, Feb 16, 2005 at 11:21:50 AM
Mullions now showing on all plans?
Thu, Nov 29, 2012 at 9:46:32 AM
Page generation time: 1.3862
