68 Users Online (66 Members):
Forums >> Revit Structure >> Technical Support >> setting out (in section ) for dome slab
45 Posts No Rating |
hi,
i need to produce the setting out of the "dome like slab" in the section to show the radius and its exact location vertically. the slab was created using revolve and its edges on the section is not selectable for radius dimensioning, please tell me how do you do the setting out of the dome in section? please help me
thanks in advance please see attached picture for detail
"Pleasure in the job puts perfection in the work"
- Aristotle |
ah nevermind, i already solved this after i abandoned this question before and deal it yesterday.
instead of creating this kind of slab using revolve command, create this using sweep command so that the "trajectory segmentation" tick box will appear on the slab property and from that you can use dimension command to put radius and everything on its section
- Aristotle |
Create a half dome |
Mon, Nov 11, 2019 at 5:37:42 PM
Slab beam Junction |
Thu, Sep 4, 2014 at 6:07:11 AM
Dome roof |
Mon, Jan 17, 2011 at 7:52:22 AM
14
Dome Roof for a Church Project |
Mon, Jan 19, 2009 at 2:44:53 PM
Section in Revit |
Fri, Jul 22, 2011 at 9:09:51 AM
Members: | 2042225 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
