145 Users Online (144 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Spot Elevations on curved walls with varying height
Fri, Apr 29, 2011 at 8:11:43 AM | Spot Elevations on curved walls with varying height
gprakash
In my current project, I have few curved walls with varying height on top. First, I created walls up to maximum height. To achieve varying height, I created 'Swept Blend' Void and cut the wall. All worked fine. But when I tried to add 'Spot Elevations' to show top levels of those walls at various locations on plan view, revit doesn't allow me to place the spot elevations.
Could anyone please help with suggestions. Thanks.
Also, I tried another option by adding sloped floor - Attaching the wall top to sloped floor - Hiding the sloped floor. Now I am able to add spot elevations on top of walls at various locations on plan. I cannot do this procedure for all other walls since the walls are too curvy and sloped floor following those curves doesn't give the result as desired.
Fri, Apr 29, 2011 at 8:55:54 AM | Spot Elevations on curved walls with varying height
This is not good that you can't elevate these points - I have not checked it out.  You should bring up with autodesk....
You may have to place a model element... just a "point" where you need an elevation.... a face based family should work.
Tue, May 3, 2011 at 5:26:47 AM | Spot Elevations on curved walls with varying height
gprakash
Thank you. A tiny 'Face based family' solved my purpose.
However, need to raise this to Autodesk as suggested.
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:12 AM
The same (one wall) to have varying thickness in its width dimension not height?
Thu, Mar 1, 2012 at 10:17:44 AM
Varying eave heights on roof [ 1 2 ]
Wed, Aug 11, 2010 at 8:21:38 PM
23
Spot Elevation-overall height issue
Fri, Apr 1, 2016 at 10:49:52 PM
REV 2009 Spot elevations
Thu, Jul 14, 2011 at 1:27:45 PM
Page generation time: 1.5918
