38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> 3D CAD to Revit
Thu, Apr 28, 2011 at 1:30:30 PM | 3D CAD to Revit
MrMcPike
MrMcPike Avatar
Hello all Reviteers,
Got an issue here at the local design firm.  Our client uses 3D CAD and i use Revit MEP on ALL my projects. So, I exported thier plan to IFC and placed the CAD import under the IFC all in Revit.  Once i halftoned the import, the floor plan doesnt look all that bad!! However, what do i do if i need to update my backgrounds? im not concerned with updating the CAD import... thats easy. but how do i update the IFC walls? Should i tell my client that whatever plans we recieve in the beginning r the ones we are going with? that sucks becuase there are always updates!
Also, how do i define room names with IFC imports? just use the ones that show on my CAD import? how do i define spaces?
Anything helps.  thanks a million.
Thu, Apr 28, 2011 at 8:21:56 PM | 3D CAD to Revit
vector23
vector23 Avatar
2 Stars: 16 Votes
McPike-
i'm sure this is important to you so i'll try to
dissect it one piece at a time- but honestly-
(and of course i'm a little retarded anyway)-
i don't understand very much of what you are
saying..
you sent your client a plan that you created in
revit MEP as an IFC file.. great.. what did they
open it with?
"how do i update the IFC walls?"  you mean like
create a new IFC file of changes you made to
the revit project?
"define room names with IFC imports?" i don't know
that one but i would like to learn more about working
with IFCs myself.. i do know that IFC interoperability
is not well established at this time.. maybe you could
explain a little of the big picture about what you would
like to accomplish with IFC? and hopfully i can learn
something too..
Wed, May 4, 2011 at 7:59:51 AM | 3D CAD to Revit
MrMcPike
MrMcPike Avatar
Vector,
Thanks for replying. I guess some one of my explanations didnt make sense becuase i am not really sure of the entire process myself.  What i meant to say is... Is it possible for my MEP firm to do every project in Revit even if the architect is working in 3D CAD? i assume the use of IFC files would be used in the process.
Thoughts?
Thanks,
Owen
Revit to CAD then use current cad layer standard, how?
Sat, Mar 10, 2012 at 8:42:45 AM
Linked CAD ducts/pipes not showing up in Revit Structure 2013
Fri, Jul 10, 2015 at 8:36:42 AM
13
Auto Cad 3D and Revit 2009
Thu, Aug 20, 2009 at 7:18:39 PM
Getting CAD Linetypes into REVIT
Thu, Jul 24, 2008 at 7:11:10 PM
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 11:24:56 AM
Page generation time: 1.7763
