58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Angled Wainscoat
Wed, Apr 27, 2011 at 11:51:33 AM | Angled Wainscoat
ALICEHER
Hi All,
I am wondering what the best is to create a wainscoat that travels parallel to my stair. I created a new wall type with a sweep, but it doesn't allow me to angle the profile up the wall. In the attached image I show a model in place component - sweep with an angled path; however, I cannot seem to make a clean connection to the non-angled wainscoat which is a wall sweep. Any suggestions? I am using Revit 2012.
Thank you.
Wed, Apr 27, 2011 at 12:29:00 PM | Angled Wainscoat
pchan
pchan Avatar
5 Stars: 5 Votes
I have encountered this in the past, and there is no prefect way to solve this but to use in-place family
It is ok as long as you don't have a lot of this wainscoat in the project.
You cannot join the in-place with the system sweep together....
you will have to create the hoz one as a in-place in order to join together.
HTH
Making Angled or canted walls
Tue, Jun 3, 2008 at 2:10:08 PM
angled corner joint - how to lock angled corners
Thu, Jul 18, 2013 at 5:10:12 AM
11
Misbehaving (stacked) wall
Sat, Apr 15, 2017 at 11:11:21 PM
Angled Window (angled jambs on both sides)
Wed, Apr 13, 2011 at 9:48:15 PM
Angled window opening in plan view
Thu, Aug 15, 2013 at 2:18:13 PM
11
Page generation time: 0.2141
