110 Users Online (109 Members):
Forums >> Revit Building >> Technical Support >> Grids and Walls
![3.5 Stars: 5 Votes](/images/stars_3.5.gif) |
Is there a way to lock walls to grids as you draw them, not later by aligning and locking? I bet there is.
![3 Stars: 10 Votes](/images/stars_3.gif) |
The closest answer I can give you is: When you draw a single wall, you can hover over the lock symbol & activate the lock. It does not work when the 'Chain' box is checked.
![thetabest Avatar](user_avatar/231785.jpg)
![3 Stars: 2 Votes](/images/stars_3.gif) |
If you draw your walls while "picking" a line, or rather a grid, then you should be able to lock it at that point. Otherwise, just draw an exaggerated layout, and then align and lock everything. Then there is what mhans pointed out, that if you draw a wall one by one, without the chain box checked, then you can constrain the wall... But aligning is by far the funnest way to do things... Right?
Trent Best
Best Systems
the.tabest@gmail.com |
Grids at an Angle in Plan don't display in Elevation |
Thu, Apr 26, 2012 at 2:44:38 PM
grids |
Tue, Nov 22, 2005 at 3:36:18 AM
i need to show colums, bearing walls and primary structural grids in my revit.. |
Mon, Mar 31, 2014 at 7:57:09 AM
DIMENSIONing GRIDS - on plan view |
Thu, May 26, 2011 at 1:33:19 PM
new user - copying grids to other levels |
Mon, Dec 6, 2010 at 3:06:35 PM
Members: | 2017305 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
