70 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> editing an inclined wall
Sun, Apr 24, 2011 at 2:53:35 PM | editing an inclined wall
hindtaj
hi there, I have crearted an inclined wall using the masses. when ever i try to edit the walls to create the elevation i dont get the "edit profile" option, i only get the "remake" option.
PS: the mass is almost in the shape of a pyramid and the walls are created using "wall by face". It is a (Basic Wall: interior 4 7/8" partition)
Please if anyone knows how to fix this issue i would be very thankful
Mon, Apr 25, 2011 at 5:28:21 AM | editing an inclined wall
4 Stars: 202 Votes
You cannot "edit profile" of a wall created "by face", if you want to change anything in that wall you need to change the "MASS", then "Update to Face", that's how it works.
Mon, Apr 25, 2011 at 12:02:20 PM | editing an inclined wall
hindtaj
Thanks alot for your reply. but what if i want to add glass in the middle of the wall or something...how can that be done??
PS: sorry i still have alot to learn in this revit.
Tue, Apr 26, 2011 at 4:05:46 AM | editing an inclined wall
4 Stars: 202 Votes
You can insert "Windows and doors" in that wall but they are not being inclined, to do that, you have several ways, just cut a hole in that wall and then you can create an "In-place" family (window or door or a simple glass), or, you can create a "Generic model Face Based" family, you choose.
Windows/opening/curtain system on inclined wall
Tue, Apr 21, 2009 at 5:16:46 AM
adding a parameter in an inclined wall family
Mon, Dec 29, 2008 at 5:29:49 PM
Inclined curtain wall
Wed, Jul 30, 2014 at 11:43:14 AM
concrete beam on top of inclined wall
Wed, Jun 20, 2007 at 11:09:18 AM
Inclined tapered walls
Fri, Oct 18, 2013 at 7:59:07 AM
Page generation time: 2.1749
