Forums >> Revit Systems >> Technical Support >> MEP 2012 Electrical Tick Marks Problem
Fri, Apr 22, 2011 at 3:53:40 PM | MEP 2012 Electrical Tick Marks Problem
ryan89
We just upgraded to 2012 and are slowly noticing issues and fixing them. This one has us baffled though. I'm fairly new to Revit so I apologize if this is simple.
When adjusting the tick marks for wires for a circuited fixture, I can't seem to make the number of conductors for any of the types (0). For example, tick marks to a switch should be (2) hots, (0) neutral, and (0) ground (we don't show ground ticks except for isolated grnd). Revit 2012 will not let me change the neutral or ground tick marks to (0); it must be (1) or higher.
Is there a setting somewhere I am missing? MEP 2011 allowed me to change those numbers to anything I wanted. I never used it, but I heard MEP 2010 had a similar issue that was corrected in 2011 so it sounds we took a step backwards.
Thanks!Ryan
Thu, May 26, 2011 at 2:06:55 PM | MEP 2012 Electrical Tick Marks Problem
SSCHMIDT
you should be able to go under your home tab and electrical tab there is a arrow at bottom if you go in there and select wire you can remove what tick you want to show up and if you have nothing in there it wont show a tick
Thu, May 26, 2011 at 4:46:24 PM | MEP 2012 Electrical Tick Marks Problem
ryan89
There are times we need to show the ground (isolated ground, outdoor circuits) and times we show the neutral. Changing the setting would prevent those tick marks from showing up for every circuit.
custom tick marks
Sun, Dec 9, 2007 at 12:35:48 PM
Heavy End Tick Marks disappear
Thu, Jul 15, 2010 at 1:55:44 PM
Tick Marks in Dimensions
Tue, Sep 9, 2008 at 10:18:47 AM
Electrical Home Runs - Revit MEP 2012
Thu, Jul 14, 2011 at 12:40:08 PM
2012 upgrade - missing type marks
Wed, Jul 13, 2011 at 11:12:39 AM
Page generation time: 3.2685
