Forums >> Revit Building >> Technical Support >> array on path
31 Posts No Rating |
Is there any way of making array of familes on smoe curved path?
Did you try with "Railings"? (if this is what you realy want...)
3 Posts No Rating |
hi,i'm new in revit and i want creat railing like this,bud i cant pick spline path please tell me more than this image(sry for my english)
thank you
3 Posts No Rating |
hi again.no help?
i want to creat railing on spline path(like image-post #2)and set my object for array as baluster,the question is how typhoon can do this?(again sry 4 my english)
thank
You can't use the pick tool to select the path, don't work, you need to re-create that path with arcs.
3 Posts No Rating |
thank you for reply
Array along a curved path |
Tue, Nov 11, 2014 at 9:11:45 AM
how can I array along spline? [ 1 2 ] |
Fri, Nov 28, 2008 at 7:07:32 AM
19
Associated Parameters in Array Family |
Mon, Feb 27, 2017 at 8:44:36 AM
Divide comand |
Thu, Oct 5, 2006 at 9:38:51 AM
Creating an Array along path |
Thu, Sep 6, 2018 at 10:56:48 AM
Members: | 2103991 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
