36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Massing form Autocad
Tue, Apr 19, 2011 at 11:07:46 AM | Massing form Autocad
greg1970
We have a solid modle from autocad that we have imported into Revit and created an inplace mass with it.  We bring the massing studies into revit then paint the surfaces to give them a quick material so we can do some quick 3d studies.  We are having some difficulty dealing with the mass and it may be the way we have imported it or revit simply cannot do what we want it to do.  The problem(s) are as follows:
When trying to edit the mass (once inported from cad) we cannot edit it.  We can add to it but we cant changed the imported geometry.
The Mass from cad comes in on layers, for example, all the glass is on a glass layer and all the doors on massed on a door layer, the beams a beam layer, etc.  So we can isolate different parts of the mass by turning on or off the layers in the VG under the import category. When painting these different mass parts it only allows us to paint it face by face - a painstaking process you can imagine.  We can isolate the glass layer so all the mass that is glass is showing but we cant just select it all and make it all glass in one command.
So my question is there some parameter or method we can bring the different parts of the cad mass into so we can  then globally assign a material.
Tue, Apr 19, 2011 at 11:56:12 AM | Massing form Autocad
3.5 Stars: 395 Votes
I don't know why you would mass in CAD instead of Revit but I guess - lessons learned.
No, you can't edit an imported mass.
Did you know you can assign materials to imports by layers?
Tue, Apr 19, 2011 at 1:54:57 PM | Massing form Autocad
greg1970
Well I can mass way faster in cad than in Revit.  I can do both well so its not for lack of experience, but cad is almost like sketchup and you dont have to go through all kind of gymnastics to creat different masses and move them around.  To each his own I guess.
But I am intrigued about assigning materials to layers.  Can you give me a quick idea of how?  I'll figure out the details, just need the basic concept.
Tue, Apr 19, 2011 at 2:54:33 PM | Massing form Autocad
Manage tab / object styles / Imported objects tab / expand the list uder your import and assign the material by layer.
BTW .... Massing in Revit only gets easier if you use it.
Fri, Apr 22, 2011 at 10:52:37 PM | Massing form Autocad
vector23
vector23 Avatar
2 Stars: 16 Votes
hi greg-
here is the way i look at the topic you are asking about-
a DWG wireframe model can come from many different modelling
programs.. it's like an artist's sketch of something that you
can build in revit.. but it's not anything that can actually
be used as part of a revit model.. it's just for reference..
if you are going to change any materials to the import layers-
the best is an off white for all of them- so you can render it and
see better the shape of its parts.. remember the whole imported
mass DWG is for reference only.. and it's a better idea to
import that DWG as a mass into a SEPARATE session of
revit- (DWG lines mix in a revit project like oil mixes
with water)..
if you are trying to see better the different parts of that
mass by turning layers on and off- a better way is to
section-box it or use an elevation clip line or cut it at
a certain depth in plan view- sections etc. etc.
i use the measure tool only and measure parts of it as i
build it in my revit project.. i also constantly use the
windows snipping tool and import the image into
my project to create revit elements accordingly.. you
adjust the image to scale and of course you have to
make sure you get the DWG import scale correct
in the first place.. i always import black lines only..
but you might change those line colors to see your imported
image snippets better..
i know autodesk is now marketing the massing part
of revit as a separate stand-alone program for design
artists- but most designs come from a .skp or a .dwg..
i guess the big idea with revit massing is that you can
use the "building maker" tools and place walls on the
massing lines- but that don't make much sense to me
because massing is just a conceptual sketch and the
lines are not precise enough for walls at that stage..
so it's really the same as a DWG mass import as far
as i can see.. but still i don't use revit massing to
be saying too much about it.. i always considered
revit to be a virtual construction and documentation
program- rather than a design program.. however
after seeing the flood of artists going for revit and
posting their designs in the gallery- i guess revit
is for design too..
>>>stuck with creating massing form in revit<<< HELP!
Fri, Nov 6, 2009 at 4:07:53 PM
Conceptual Massing Problems
Sun, Jun 28, 2015 at 10:22:44 AM
void form and cuttng void form
Fri, Jul 9, 2010 at 12:39:02 PM
Import Massing to AutoCAD
Fri, May 30, 2008 at 3:28:45 AM
aligning two curtain walls/panels in a Blob-like form
Wed, Jan 22, 2014 at 1:39:53 AM
Page generation time: 0.4225
