59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> how to make a corner sweep
Sun, Apr 17, 2011 at 11:08:18 PM | how to make a corner sweep
fairywiner
look , I have sweeps at the corner of the wall, not vertical angle, I don't  know how to make it. is that I have to make some spcial sweeps in the family? and I then made a special sweep, and upload into project, it seems that the sweep direction is not coordinance with the family, I intentially mada a small bulge on the sweep,so it is easy to tell the direction.
沧海月明珠有泪
Mon, Apr 18, 2011 at 7:24:01 AM | how to make a corner sweep
No sure what you are asking.  If you are appling a vertical corner "wrapping" sweep, they are hard to do because Revit may not agree with you as to which face is hosting the sweep.  I usually build these offset from their insertion point so that I can place them on the face back away for the corner.  BTW, You may need a left/right hand if the sweep is not symetrical.
Mon, Apr 18, 2011 at 12:00:50 PM | how to make a corner sweep
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Also not quite sure where you mean for the sweep to be, but when you start sketching the path of a sweep, before you start, you have an option to "pick 3D Edge" for the path.  This is to the right of the line options, and different from the pick line option..
This allows you to make complciated 3D sweeps along existing geometry.
Wall Sweep at the Corner
Mon, Mar 25, 2013 at 1:20:46 PM
Corner Trim with Vertical Sweeps
Thu, Aug 31, 2017 at 2:32:52 PM
Complex Sweep Not Working
Sun, Feb 21, 2010 at 8:05:52 AM
Sweep Corbelling Trim on the Corner
Fri, Apr 8, 2016 at 1:04:27 AM
wall sweep inside corner
Mon, Dec 18, 2006 at 9:07:05 AM
Page generation time: 1.5300
