86 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> why I can not copy wall sweeps
Sun, Apr 17, 2011 at 10:25:58 PM | why I can not copy wall sweeps
fairywiner
look, my building is like an art deco style, so I need to made many sweeps on the wall, the problems is I can copy  the sweeps, I can just have to put it one by one to use wall sweep, when I copy a sweep, there always ejected an dialog: element were deleted.  Is that wall sweep can  not be copied at all ? thanks.
沧海月明珠有泪
Mon, Apr 18, 2011 at 7:17:47 AM | why I can not copy wall sweeps
First, you can copy wall sweeps and reveals on the same wall face.
If this profile is not cut by a door or a window, you can always consider doing an in-place sweep that has multiple closed profiles.
If you don't mind these sweeps showing up in plan, you can add them to your wall definition.
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:42 PM
Sweeps
Tue, Mar 27, 2007 at 9:47:02 AM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:56 AM
Outlets and Wall Sweeps
Wed, Feb 29, 2012 at 9:39:47 AM
widow head and sill sweeps
Sun, Dec 11, 2005 at 5:46:14 PM
Page generation time: 1.6101
