104 Users Online (101 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Complex forms/Revit capability
Mon, Nov 14, 2005 at 9:54:59 PM | Complex forms/Revit capability
pvanko
Is there any way to generate Gehry-like forms in REVIT? I used ACAD for complex modeling in school andsuccessfully produced some convincing imitations. However, I'm puzzled by REVIT in that when you sketch a roof, it's very one dimensional. I have a feeling that you have to derive the geometry from masses, but how you get there I am not sure. I imagine if you create the roof and get the walls started from the mass, you could then attach one to the other?
Mon, Nov 14, 2005 at 10:05:20 PM | RE: Complex forms/Revit capability
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You are correct with your assumptions of masses. The advantages of masses is they can be edited and then all associated geometry can be regenerated based on the changes. A mass can contain any geometry. You can import free form nurbs in SAT and DWG formats for use as a base to construct your walls/roofs/floors as required.
Sun, Nov 20, 2005 at 9:31:01 PM | RE: Complex forms/Revit capability
pvanko
I love that ability to create smart building components from masses! Add in the parametric capability-- what a package. However, wouldn't it be nice if you could control curtain sytems created from masses (dtermine if "1" or "2" is horizontal or vertical)...as of now, a door inserted into my mass' curtain system turns 90 degrees sideways. From what I can tell from an earlier post here and one in the Autodesk discussion groups, it is going to be addressed in the next version. Thansk again!
Wed, Jan 3, 2018 at 10:14:33 PM | Complex forms/Revit capability
archie1492
Flattening 3d Forms, CNC Cut Parts I'm modeling a catamaran in Revit as kind of a challenge to myself to improve my 3d Revit skills. I'm wondering if there is a way to flatten the 3d surfaces, so that I can CNC cut them for a scale model? I know Rhino is capable of this, but I'm most skilled with working within Revit. Does anyone know if Revit via a plugin or natively has this capability? I'd like to flatten 3d forms for laser cutting the surfaces. I'm using Revit 2018.
Edited on: Wed, Jan 3, 2018 at 10:14:57 PM
Edited on: Wed, Jan 3, 2018 at 10:16:42 PM
Complex curved forms
Fri, Jan 4, 2008 at 2:37:03 PM
Complex Geometry
Thu, Jan 25, 2018 at 7:57:49 AM
Need forms for a residential environment.
Thu, Mar 8, 2012 at 7:13:25 AM
I hope for tutorials on curved forms
Fri, May 14, 2004 at 4:09:16 PM
Complex Revit Drawings
Wed, Feb 2, 2011 at 5:55:23 PM
Page generation time: 4.3563
