39 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Can an Elevation View be duplicated and mirrored (without mirroring the model)?
Fri, Apr 15, 2011 at 4:11:05 PM | Can an Elevation View be duplicated and mirrored (without mirroring the model)?
JulieJ
What I would like to do is to be able to copy and mirror an Elevation View without having to copy/ mirror the actual model elements.  This would be useful for our firm to study building elevations for a multi-unit development where units that are mirrored exact replicas  occur without having to update multiple models  as we develop the design – we would simply create a view of the building elevation we are studying then duplicate the view and mirror it, then place the 2 views side by side on a sheet.
I don’t think this feature (mirroring a view) is something that Revit can do, but if you know any tricks let me know.  I realize that the only way to do this might be to link the model to another file and try to mirror it there.  I'd appreciate any tips!  Thanks.
Fri, Apr 15, 2011 at 11:51:41 PM | Can an Elevation View be duplicated and mirrored (without mirroring the model)?
tomdeplater
tomdeplater Avatar
1 Stars: 1 Votes
you could also export the original elevation as a DWG then import it into a new elevation view and mirror the cad work.  If you linked this DWG, then any time you change the original elevation you could just save over the DWG and reload the mirrored view to update the changes.
_tom
www.revittutorialsonline.com ::
Sat, Apr 16, 2011 at 9:20:10 AM | Can an Elevation View be duplicated and mirrored (without mirroring the model)?
Revit is a model program, not CAD.  Tom's answer is what you will have to do.
Tue, Apr 19, 2011 at 3:21:44 PM | Can an Elevation View be duplicated and mirrored (without mirroring the model)?
bert
Why not group your facade, and mirror the group? You'll still have a larger model, but you only have to set it up once and edit either one of the groups to reflect the change on either side.
I just feel that over time, exporting, linking, and reloading will only be a waste of time.
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Switches in a mirrored linked revit model
Fri, May 22, 2020 at 7:44:20 AM
Model Pattern in Mirrored Groups
Fri, Apr 17, 2009 at 5:23:13 AM
Mirroring House model
Wed, Oct 27, 2004 at 4:33:14 PM
Mirroring entire project- "copy" check box greyed out?
Sun, Apr 23, 2006 at 6:44:57 PM
Duplicated view - perset
Fri, Jun 15, 2007 at 10:49:53 AM
Page generation time: 2.8351
